Mercruiser Alternator Upgrade? >
Old 08-07-2016 | 09:47 PM
Default Mercruiser Alternator Upgrade?
Hey guys, is there an upgrade for the old Mando "4-wire" alternators? I have gone through a number of these things over the years due to salt water, broken motor mounts, etc and burned up a voltage regulator on one today. Is there anything out there that's more corrosion resistant or tolerant of a splash of water? I would like to stick with my single groove v-belt set up for now too.
Thanks!
KevD815 is offline
Old 08-08-2016 | 01:45 PM
I don't know of anything definitive but DB Electric is a good source to talk to.
Baja Rooster is offline
Old 08-08-2016 | 02:19 PM
I have two good ones sitting on a shelf from when I converted to 1-wire... Make me an offer
jamontes is offline
Old 08-08-2016 | 07:13 PM
blue thunder's Avatar
dbelectrical.com makes a good one wire marine alternator at 105 amps with a vee groove pulley. Just have to run a single 6-8 ga wire to the positive on the battery and a ground wire from alt to block and you are done. Cap off all other wires. Simple is best especially is salt. The last one I bought was $57 to my door and that was a week ago.
blue thunder is offline
Old 08-08-2016 | 08:11 PM
BUP
I am API dealer, they will cost more than the DB Electric but the quality is by far alot better. Also API Marine products are USA assembled and quality control tested as well.
BUP is offline
Old 08-09-2016 | 06:36 PM
How much for a similar api one wire alternator bup? I agree china is not always the best supplier so reputable options would be good.
Old 08-09-2016 | 09:24 PM
BUP
Sorry I am out till Monday I can call them but in the meantime it would wise to see what mount configure you will need to get a price on the exact one needed for your set up and brackets
try looking at their website and I can try to call them Thursday if all possible - (you) ----- see if you can post the API part number that would work for your app. I will comeback to see if you found anything from API then call them. THANKS
BUP is offline
Old 08-09-2016 | 09:49 PM
Rookie's Avatar
I've run db electric alternators for 7-8 yrs now. Quality is great and the only problem was spinning off a pulley on a reverse rotation engine. (my fault)
Rookie is offline
