How do I know which axles I have? >
Old 08-09-2016 | 08:32 AM
Default How do I know which axles I have?
8 lug on 6 1/2
3" diameter axles.
I`m gonna pull the trigger on EOH but it seems my axles could be from 6K to 7200#
ICDEDPPL is offline
Old 08-09-2016 | 09:14 AM
ben
8 lug is 7k
6 lug is 5k (sometimes 6k)
5 lug is 3.5k
This is for 99% of trailers so I would say you have 7k axles.
ben is offline
Old 08-09-2016 | 09:17 AM
I just did one. The spindle diameter determined the weight
class6 is offline
Old 08-09-2016 | 11:46 AM
Are you giving up on straight electric?
ezrizer is offline
Old 08-09-2016 | 12:00 PM
6000-8000lb all use the same spindle if they are dexter or rockwell. They use a smaller outer bearing on the 6000, but the bearings on 7k and 8k are the same. On electric drum brake axles, shoe width and lug size are the only differences between the 7k and 8k. Ultimately, it should be listed on the VIN tag on the trailer though.
wfo1 is offline
Old 08-09-2016 | 11:57 PM
I noticed only a couple wheels lock up when the trailer is empty. Not sure what they need but every raves about the EOH so instead of bying new part for electric I might as well...
ICDEDPPL is offline
Old 08-09-2016 | 11:58 PM
Trailer Bearing Kit, 1 1/4" x 1 3/4" Spindle, 14125A/25580 Bearings
ICDEDPPL is offline
Old 08-10-2016 | 05:47 PM
Please post the final results, I'll be crossing that bridge later in the year and will need to make a decision on which way to go.
ezrizer is offline
Old 08-10-2016 | 07:35 PM
jeff32's Avatar
i think those are the bearing i have and mines are 7 k, but tires limits my total weight to 18k
jeff32 is offline
Old 08-29-2016 | 07:38 PM
You are correct. Found this informative
http://www.easternmarine.com/downloa...aces_seals.pdf
ICDEDPPL is offline
