Thru haul exhaust questions
Thanks guys for taking the time to read this. Planning on doing some thru halls on my 1996 200 BR CELEBRITY w/ 350 mag. I have a couple question before I do the install. So when the boat is sitting in water, with people in back the water level looks like it's going to be right at the bottom of the tip. From my current measurements, and degree off the riser to the location, it looks like it's going to be sitting at a 20 degree angle from riser to tip. The riser that are on the 350 mag look and measure to a 6 inch riser. Is there anything I should be concerned about with these numbers?
Will post pics,
Thanks in advance,
Nick
https://drive.google.com/file/d/0B8v...ew?usp=sharing
https://drive.google.com/open?id=0B8...VzVUl0ZFg4QXZR
https://drive.google.com/open?id=0B8...5NUjJaVkdiUm1F
https://drive.google.com/open?id=0B8...J5Q2t2OWRyUmJ3
So the little hole where the fish finder comes through is going to be almost the center point of where i want to have the tips come through. There are lower water lines, but im playing it safe with the higher lines.
thanks.
Will post pics,
Thanks in advance,
Nick
thanks.
If you are coming straight off of the riser and to the transom you should be good. You want a downward slope towards the back of the boat. You will want to run tips that have internal flaps and also run a set of the external rubber flaps to keep water from coming back up the tail pipes when coming to a stop or if a wave hits the back of the boat while parked.
