need a 502 reverse rotation! >
Old 08-17-2016 | 09:08 AM
Default need a 502 reverse rotation!
I hope I am not the only one to have this problem!
i bought a great hull it is an Italian boat produced by the Carlo Riva in a company he set up when he sold his Riva company.
the hull was design by Bob Hobbs the interior is more Italian elegant style rather than racing style (sorry...). it is a stepped hull with my old engines I hitting 60mph and with proper engine should go 70mph! the boat appear in "james bond: Golden eye".
That much for the boat.
http://www.yachtforums.com/threads/m...32.9358/page-2
Now the bad news i discovered by checking the casting numbers that in fact I have on the left side a recent 502 gen VI standard rotation LH (about 200 hours) and on the right side an old 454 'reverse rotation") Mark IV!
Obviously I want to replace the old 454 by a new 502 but these seem to impossible to find the limiting factor is the RH camshaft that are a struggle to find
LEFT MOTOR 502 LH
block casting number 19165956 Gen VI
head casting number 12562934 HI PERF
intake Casting number 6269318 HI PERF
Camshaft??
Carb HOLLEY 750
RIGHT MOTOR 454 RH (to be replaced y new 502)
block casting number 10051107 Mark IV
head casting number 14096188 HI PERF
Camshaft??
Carb HOLLEY 750
so itis relatively easily find 502 standard rotation !
but how to find a New 502 Reverse rotation??
or at least a RH camshaft that can be mounted in a new 502 gen VI Block??
Thanks in advance for any tip
Iaranicki is offline
Old 08-17-2016 | 09:21 AM
F-2 Speedy's Avatar
So its an inboard V-drive ? hence the need for the reverse rotation............cool boats
F-2 Speedy is online now
Old 08-17-2016 | 10:58 AM
Yep inboard
- 2x502s
- 2x72c 1:1
- 2 Big (truck like) shafts to the V drives that are mid boat for better weight balance and shallow angle
- 2xBPM V drives 1,17:1 superbe heavy duty Italian V drives tested for 10000 hours minimum!
Just need the right engine to be a 502....
Old 08-18-2016 | 08:27 PM
Can't Marine Kinetics grind you the cam that you need?
Baja Rooster is offline
Old 08-19-2016 | 06:55 AM
I reversed one my motors. Cam. Distributor gear and starter.
kaje is offline
Old 08-19-2016 | 07:36 AM
Can't you just get a timing gear set instead of the chain. Change the distributor and be done with it?
class6 is offline
Old 08-19-2016 | 07:59 PM
Have one of the Cam Companies ( I use comp but anyone can do it ) grind you a reverse rotation cam , Or you might be able to find you a 2 Gear drive ( Like the 3.0L Chevy) to run the factory cam in LH rotation , while your crank runs in the RH Rotation. You will also need a reverse rotation starter .
dunnitagain is offline
Old 08-19-2016 | 09:14 PM
The gear set will allow the crank to turn RH rotation while the am still turns normal. It's all you need. No big deal.
class6 is offline
Old 08-21-2016 | 01:43 AM
Class 6
I like your suggestion
have you had any reference for such gear for a 502?
Any experience with such setting is it reliable??
It is great idea but none of the engine shops proposed this option...
Old 08-21-2016 | 01:54 AM
Yeah
I like to gear option but never seen it on a 502 and no shop proposed it.
Re camshaft Grinding a cam is the option
But was lazy I guess trying to get a motor ready to go...
