5.7 timing with comp 270 cam
I think a better question would be what totl timing as TBolt IV distributors can't change the timng curve. That said, 30-32 total will be good. Double check at 4k to make sure your module isn't advancing still.
With a typical 24* module this will leave you at 8-10 initial. But always check/adjust by total just in case as that's more importnat.
If you have an adjustable timing curve distributor, anywhere between 12-16 initial will be fine, with again 30-32 total. All in by 3k-3500rpm is fine.
