new 540 water in oil >
Old 08-18-2016 | 06:48 PM
Default new 540 water in oil
I have a new 540 engine getting water in the oil what would be the first things to check appreciate any help. Also new oil coolers and headers . thanks
lskaracing is offline
Old 08-18-2016 | 06:54 PM
ROB FREEMAN's Avatar
Running in cold water without oil stat ? Oil needs to be 212 to boil it out. If not then I'd look into that chit. :-)
ROB FREEMAN is offline
Old 08-18-2016 | 07:01 PM
SB
Before you run it again Call the builder and ask how they want to handle it !
Intake gaskets most likely This is a % bet.
Check your water psi when running also.
SB is offline
Old 08-18-2016 | 07:15 PM
Other engine is fine on oil temp etc. Water psi is 20 at 5500 rpm. Also if I remove intake to reseal how long do I have to let the silicone set up before running it.?
Old 08-18-2016 | 07:22 PM
SB
Instantly. Which obviously will be a few hrs or more until your ready.
SB is offline
