need part # for hose transom to sea water pump >
Old 08-18-2016 | 08:20 PM
Default need part # for hose transom to sea water pump
need help can someone give me the part# for the hose that goes from the transom too the seawater pump on a merc 6.2 without quick connect
tazdevil is offline
Old 08-18-2016 | 08:27 PM
BUP
You 100 percent will need to post your engine serial number and year model.
The 6.2 started life in late 1998 with Mefi 3 and used a different style water pump than the later models. There is about 6 different versions of the 6.2 and all parts did not stay the same. Merc racing 377, towboat 6.2, MX 6.2, Black Scorpion 6.2, and so on
Also the 6.2 is used in inboards, direct drive ski boats, wakeboard boats, I/O rec boats and sportboats plus even a few jet drive boats that all have different set ups. With that said what do have as well ? Im sure you would hate for a wrong guess as to what your part number is. More info is needed on your end.
BUP is offline
Old 08-18-2016 | 08:57 PM
serial 0w032102
tazdevil is offline
Old 08-19-2016 | 01:38 AM
Mbam's Avatar
Offshoreonly Advertiser
#11 here
http://www.mercruiserparts.com/bam/s...31748/8093/210, it comes in a 8' length
Mbam is offline
