Fuel Coming out exhaust
Anybody ever had this issue Fuel coming out exhaust on 2000 500 efi replaced all the injectors, regulator's both of them, water sensor, vacuum line not plugged, all injector leads in the rite place
This year I had one of my injectors stock full on, luck would have it I was just cranking. Try pulling all plugs and just turning key on for a couple minutes. Don't crank.
Then pull your kill switch and crank with all plugs out. When I would do it on mine gas would come out. No injectors should be on. At least that is how my kill switch is wired. Same year and motor as yours.
