500 HP Intermiten Idle Issue >
Old 08-24-2016 | 07:54 PM
Question 500 HP Intermiten Idle Issue
I have a 2003 Powerquest with 500 HPS: (500 EFI's)
* Intermittingly the starboard engine revs to 1500 RPM (I shut the engine off restart - issue goes away) It will stay at 1500 RPM and will not drop down
* I can be running the boat all day and then when I come off plane - the same issue occurs (Shut to engine down - issue goes away)
* It will happen at no specific time
* I have replaced the batteries, check the battery connections and ground connections
* The ECM modules have been tuned by Arizona speed about 6 yrs. ago
Comments / Possible solutions / Feedback is greatly appreciated
Regards,
Walzman
walzman is offline
Old 08-24-2016 | 08:53 PM
SB
500EFI's ?
SB is offline
Old 08-24-2016 | 09:50 PM
Intermittent vacuum leak will cause high idle on EFI motors.
Trash is offline
Old 08-25-2016 | 10:50 AM
Yes 500 EFI's
walzman is offline
