496 HO Question
Old 09-02-2016 | 10:31 AM
NWPC's Avatar
Default 496 HO Question
What are these valves for?
They are located under exhaust manifolds.
NWPC is offline
Old 09-02-2016 | 10:39 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Looks to be drains for the exhaust water jackets.
But that is NOT a factory setup.
Sydwayz is offline
Old 09-02-2016 | 10:54 AM
NWPC's Avatar
With both closed motor codes low water pressure at WOT.
With both open motor overheats to 200 but water pressure is good
1 open and 1 closed motor runs at 174 with good pressure.
Would like to know why.
NWPC is offline
Old 09-02-2016 | 11:02 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You are going to have to chase where they go a bit. They could be a "redneck engineered" way of reducing water pressure. We use valves like that on BBC jet boats sometimes to run the headers dry or wet at times.
But you always would want to have everything wet on that motor, no exceptions.
Are your exhaust temperatures the same, always? Do both manifolds feel the same temperature? (Hint, you can check with a laser temp gun, invaluable tool to have.)
That also doesn't look like factory exhaust. Please post some more pictures.
And see if you can find where the bottom of those drain lines go to.
Also, don't trust the Open/Closed position on those valves. They could be exact opposite of what you expect. Take a hose off each one and inspect.
Sydwayz is offline
Old 09-02-2016 | 01:23 PM
I am guessing you have Dana exhaust. I have Dana too and mine are used as drains or typical flow. I dont understand why yours are set up like tees???
How old is the impeller?
Keith Atlanta is offline
Old 09-02-2016 | 03:01 PM
NWPC's Avatar
Impeller is new.
Had heads redone. Problem occurred after motor was reinstalled.
Not sure how the valves were set prior.
NWPC is offline
Old 09-02-2016 | 03:18 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
They may have been both 1/2 open.
Sydwayz is offline
Old 09-02-2016 | 07:05 PM
Disconnect the bow side and see what happens. That is the discharge for draining on my engines...
