what oil to use in hydraulic steering system? >
Old 09-06-2016 | 08:48 AM
jeff32's Avatar
Default what oil to use in hydraulic steering system?
Imco external hydraulic steering system for 3 drives
regular power steering oil?
Transmission oil? what type?
Anything else?
Thanks again!
jeff32 is offline
Old 09-06-2016 | 09:03 AM
Dave M's Avatar
Veteran: Navy
power steering fluid.
Dave M is offline
Old 09-06-2016 | 09:07 AM
glassdave's Avatar
Neno the mind boggler
i used ATF on the last couple Zeiger systems (per Zieger) what are the pros and cons of ATF over power steering fluid?
08 OPA High Points Champion
glassdave is offline
Old 09-06-2016 | 09:31 AM
Wobble's Avatar
SORE MEMBER
Redline full synthetic power steering fluid or other synthetic if you are doing a complete flush, made a big difference on my duramax steering also.(as in quieter and better feel)
Wobble is offline
Old 09-06-2016 | 09:34 AM
I always used the gm atf. Easier to see if you are getting water in it. Also use it in trim pumps.
tmmii is offline
Old 09-06-2016 | 09:59 AM
Wally's Avatar
Were doomed!
"usually" the ATF has a higher viscosity then PS fluid....but depending on who makes it or if its synthetic that may not hold true...
ATF also has detergents in it to help keep "junk" buildup n the trans....does it help for the PS system...maybe on the pump seals and maybe for the rack-n-pinion system but for a HYD steering system i'm not sure if there would be any benefit one way or the other.
I know on my wife's jeep liberty, when it gets in to the single digits in the winter time her steering system whines so badly you think a cat is being murdered under the hood!! I switched out the PS fluid to ATF and it all went away! After reading online why, it turns out that jeeps use a plastic reservoir on a metal body...when it gets cold the metal shrinks and lets air into the system and cavitates the pump causing whine...the ATF has friction modifiers to help keep it from bubbling and that's what keeps it from whining!
-Wally
Wally is offline
Old 09-06-2016 | 10:06 AM
onesickpantera's Avatar
I have used both PS fluid and ATF, never noticed a difference between them.
onesickpantera is offline
Old 09-06-2016 | 10:19 AM
BUP
That is correct Zeigler recommends ATF
One thing I have notice - Volvo Penta steering actuators can have there own problems with fluid leaks on there own - but what I have notice thru out - is the apps that have used ATF instead of power steering fluid leaked more often. at least a 2 or 3 to 1 difference in apps. Just throwing that out there.
BUP is offline
Old 09-06-2016 | 10:35 AM
I am using 10W fork oil in my Zieger system.
I didn't have power steering fluid on the shelf.
No issues in 7 years.
Ken
minxguy is offline
