Bravo 1 outdrive sagging help >
Old 09-08-2016 | 05:20 AM
Default Bravo 1 outdrive sagging help
My Bravo 1 seems to sag over 3 days. I Trim it up fully then over the next 3 days it gradually drops ? There are no leaks or loss of fluid. It seems to be working ok .
Can anybody point me where to start .
THX
Plus Man is offline
Old 09-08-2016 | 05:48 AM
I would think the rams are going. I have a similar situation with the hatch ram. No leaks, but I know its the ram not holding as its the original from 89.
sleev-les is offline
Old 09-08-2016 | 06:15 AM
Make sure the manual release screw on the trim pump is tight and maybe even pull the screw and check the o-rings. 5 minutes and 2-3 o-rings are cheaper than new rams, so that's where I'd start.
Speedracer29 is offline
Old 09-08-2016 | 12:07 PM
Valve in the trim pump motor is leaking.
Griff is offline
Old 09-08-2016 | 02:32 PM
Also out of curiosity why are you leaving it trimmed all the way up for days? That's not real good on the bellows and what not.
Crude Intentions is offline
