Going from 5.0 to 5.7 or 6,2 SBC >
Old 09-12-2016 | 09:49 PM
Default Going from 5.0 to 5.7 or 6,2 SBC
I have a VP vortex 5.0 and about about 6/7 years ago i replaced factory carb with 4 barrel holly vac secondary carb, a 4160 . Volvo uses a spreadbore intake with adapter to use a 2 barrel stock. Long story short the motor is toasted and I am re powering, I am trying to decide if I want to buy long lock with or without carb. Do the experts think I will have to jet carb or will the bigger motor pull more air and the AF ratio will remain same. I called holly tech line and the guy " I dunno".
happy hours is offline
Old 09-12-2016 | 09:52 PM
SB
Is it after happy hours ?
You have been easy to understand until now.
SB is offline
Old 09-13-2016 | 08:13 PM
Buy one with a marine carb and a marine cam! Bigger is better.
NHGuy is offline
Old 09-13-2016 | 08:28 PM
What carb is it
Mr Maine is offline
Old 09-13-2016 | 08:48 PM
I did the swap several years back on a guys boat 5.0 to 5.7 pretty much a drop in deal. We lowered the compression so we could run the factory small chamber 5.o heads reused the factory roller cam as well. We did upgraded the timing chain, intake and carb. He was on a tight budget but wanted the torque of the 5.7
If budget would have allowed a camped up alum. Headed 383 would have been nice...
noslo5o is offline
Old 09-13-2016 | 08:51 PM
Cammed....not camped...lol
noslo5o is offline
Old 09-13-2016 | 11:29 PM
Fixed typos, I concurs, it wasn't clear, it was late and I am fighting cold and was all cold medicined up. Ha.
Old 09-13-2016 | 11:31 PM
Current carb is Holly 4160. If I buy the new long block with carb it's a elderbrock something. QUOTE=Mr Maine;4481209]What carb is it[/QUOTE]
Old 09-14-2016 | 05:38 AM
SB
45cid more will usually require some more jet if all other things are equal.
The Vortec 305 was around 250hp with a 4bbl if I remember right.
Are you going with a 270 or 300 hp (or more ?) Vortec 350 ?
SB is offline
Old 09-16-2016 | 04:23 PM
[a vortex 350.
Currently I am getting my ass kicked by the trim cylinders being corroded to the drive and I can't get the drive off. Hammer with drift, air hammer and even drilled and tapped end of it and used a piece of pipe to make puller and it's stronger than 5/16 all thread, even with heat. QUOTE=SB;4481290]45cid more will usually require some more jet if all other things are equal.
Are you going with a 270 or 300 hp (or more ?) Vortec 350 ?[/QUOTE]
