How to access fuel vent hose and filler hose 2002 28'??? >
Old 09-13-2016 | 08:34 PM
Default How to access fuel vent hose and filler hose 2002 28'???
Trying to get access to the fuel filler and vent hose up top. I noticed in the closet there seems to be a cover they run behind, but its fiberglassed in. How do I gain access or how does the closet come out?
Thanks!
dawes11 is offline
Old 09-13-2016 | 10:02 PM
[ATTACH=CONFIG]559405[/ATTACH]
Attached Thumbnails How to access fuel vent hose and filler hose 2002 28'???-100_4069.jpg
OCCJoe is offline
Old 09-13-2016 | 10:28 PM
About what it looks like ill have to do......
dawes11 is offline
Old 09-14-2016 | 01:38 AM
On my 1996 28' the access to the fill hose was in the closet. Its in the boxed area in the back corner.
Mine just had carpet over part of the boxed area and all you had to do is remove the carpet.
As far as accessing where the hoses meet the tank, if you pull back the lonseal floor, there is an access hole in front of the passenger side bolster.
I was getting gas fumes in my cabin. It turned out that the clamps on the filler hose at the fill neck had come loose.
Griff is offline
Old 09-14-2016 | 06:46 PM
I found the box in the closet, I peeled back some of the lower carpet though and it seems like it is glassed into the bottom and sides. Ill pull the carpet all the way off and take a picture.
Appreciate the help so far
dawes11 is offline
Old 09-16-2016 | 12:15 AM
I finally got the access. It was glassed in on both sides of the box on the closet. I used a small wedge to work under the tabs and separate it. Thanks for the info guys
dawes11 is offline
