Boat plugs out with pipe dope >
Old 09-17-2016 | 12:37 PM
ROB FREEMAN's Avatar
Default Boat plugs out with pipe dope
Man want to drain n get sand n debris out of block. Holy crap they don't want to come. Any secrets . They are brass with pipe dope on them and are there to stay.
ROB FREEMAN is offline
Old 09-17-2016 | 12:39 PM
vintage chromoly's Avatar
Maybe a little heat?
vintage chromoly is offline
Old 09-17-2016 | 01:10 PM
That's what I was thinking too !
Old 09-18-2016 | 05:36 AM
Ayuh,.... Use a wrench or socket,....
They should never be installed that tight,....
Just abit more than finger tight is plenty tight enough,...
Bondo is offline
Old 09-18-2016 | 09:55 AM
Talking
Put some muscle in it you p*ss*!
ICDEDPPL is offline
Old 09-18-2016 | 10:14 AM
6 point socket and eat your wheaties.and not the catylin jenner kind.
sutphen 30 is offline
Old 09-18-2016 | 10:15 AM
I have seen idiots use furnace pipe dope/sealant,,only thing to break it is heat.is the dope brownish by chance?
Old 09-18-2016 | 10:33 AM
3/4 inch impact and a socket
MILD THUNDER is offline
Old 09-18-2016 | 11:27 AM
Are you talking about your core plugs?
There's space behind them. Drill a hole and put in a tapping screw, grab it with a pair of side cutters (formerly known as dikes) and lift against a piece of metal as perch for a lever.
Or slide hammer while heating the edges.
I feel kinda dumb now, I installed my plugs with thread sealant.
If it's the block drains, I'm out. The guys who answered have it.
NHGuy is offline
Old 09-18-2016 | 12:03 PM
Try hitting them with a hammer, this will definitely help. I have had to do this a few times. After hitting them most of the time they will break loose.
Brandonb_05 is offline
