525 Edelbrock head >
525 Edelbrock head
525 Edelbrock head
Old 09-21-2016 | 10:11 AM
F-2 Speedy's Avatar
Default 525 Edelbrock head
Does anyone have the specs on these, valve, combustion chamber, runner size, how well do they flow. Could you compare them to an AFR ??
F-2 Speedy is offline
Old 09-21-2016 | 11:19 AM
I have no idea which head that is, but my Performer RPMs flowed at .700 lift in335 and ex244
Baja Rooster is offline
Old 09-21-2016 | 10:20 PM
pretty much aluminum version of a gm rect port head,not remotely close to a good afr head.
mike tkach is offline
Old 09-21-2016 | 10:24 PM
Read up on them months ago. Conclusion was there were designed to merc specs and nothing special. Thought they were 310 runner. I was gonna use them on some long blocks to sell but decided not to.
getrdunn is offline
Old 09-21-2016 | 10:34 PM
pretty sure the only thing different from the non merc head is the exhaust bolt location on two bolts holes,that way merc thinks they can sell replacement heads.
Old 09-21-2016 | 10:44 PM
SB
Yup. that makes it proprietary. And thus mega money. LOL.
SB is offline
Old 09-22-2016 | 06:08 AM
F-2 Speedy's Avatar
I bought a pair of 525 long blocks assembled, Im wanting to make 600 ++ hp from these with a Vic jr. intake and a 850 carb is that reasonable ?
Would a different off the shelf cam be better the same springs ?
Old 09-22-2016 | 06:50 AM
SB
I think a good estimate will be near 570 -580hp. From what I've seen the AFR's should put in another 30hp or so.
Here is some flow data on the 315 Edelbrock Performer RPM heads.
http://www.airflowresearch.com/bbc-shootout/
PS: if you get fixated on the hp/tq #'s on this article, remember it's got a solid roller and just use the power #'s to compare the heads.
SB is offline
Old 09-22-2016 | 08:25 PM
dart now has a cnc'd head for the 525 I believe.
sutphen 30 is offline
Old 09-22-2016 | 09:21 PM
http://dartheads.com/dart-product/pro1-24-525-mmr/
MILD THUNDER is offline
