AFR numbers  what's good and what's bad .. >
Old 09-22-2016 | 07:52 PM
Default AFR numbers what's good and what's bad ..
I ran my not the other day with a wideband and was curious where I should be wide open and cruise
excalibur82 is offline
Old 09-22-2016 | 08:14 PM
what do you have for engines?
cruise 12.5-12.8 na/boosted
wot 12.2-12.4 na 11.9-12 boosted
and always give a quick visual to the plugs,,make sure theres no shiney speckles.thats bad
sutphen 30 is offline
Old 09-22-2016 | 09:56 PM
X2. Stay under 13.0
getrdunn is offline
Old 09-22-2016 | 11:02 PM
NA pump gas: Cruise 14 to 1, WOT 12 to 1
BenPerfected is offline
Old 09-23-2016 | 07:12 AM
My cruise is like 13.2 and my wide open is 12.3
Old 09-23-2016 | 10:30 AM
I will echo what others have said. My numbers are nearly identical to yours. I run wide band full time and have been doing so for 6 years. Cruise I target 12.8-13.2. At WOT I target 12.5 or less. No load idle I target 13.8-14.0. Idle in gear 13.5.
Trash is offline
