Best Carb Spacer 4 hole or Open? >
Old 09-25-2016 | 08:46 AM
Craney's Avatar
Default Best Carb Spacer 4 hole or Open?
I'm thinking about adding HVH super sucker carb spacers but not sure which one, open or 4 hole? I have 496s with 850 Quick Fuel carbs sitting on Victor jr intakes,305 AFR heads and Bob M cams. I'm just not sure which one would work best for set up.
Craney is offline
Old 09-25-2016 | 09:10 AM
you'll never notice the difference in your boat.I'd go w/ the 4 hole if your buying one.
sutphen 30 is offline
Old 09-25-2016 | 09:29 AM
it really depends on what the engine wants. so just choose you wont notice the difference either way. id go with a phenolic material vs the metal just to keep the carb cooler.
beaver 3 is offline
Old 09-25-2016 | 09:46 AM
bck's Avatar
bck
Charter Member#568
I tested with a very similar setup. The engine did pick up power with the spacers. There was no difference from open to 4 hole, I checked both. I made about 15 hp and 10 lbs more with a 2 in spacer over no spacer.
Straight bottoms and flat decks
bck is offline
Old 09-25-2016 | 10:34 AM
No difference hp wise from pro comp spacer to hvh other than price tag. HRE makes the best spacers if your trying to get everything out of the combination however as said in a marine application it's not really worth the added expense... Sad to say but chinese is the way to go.
Black Baja is offline
Old 09-25-2016 | 08:53 PM
Some like both. 1" 4 hole with another 1" open sandwiched together. Can be trail and error. Given your close to bck's build I'd probably use what he did to his for starters. Then again two identacle engines may like something entirely different.
getrdunn is offline
Old 09-25-2016 | 09:56 PM
SFOcean's Avatar
Charter Member #394
4 hole improves carb signal; open adds plenum volume. I would agree with 4 hole on your engine.
SFOcean is offline
Old 09-26-2016 | 12:02 AM
We made the best power with a 4 hole stacked on top of an open.
offshorexcursion is offline
Old 09-26-2016 | 12:47 AM
articfriends's Avatar
Any reason you didnt go with a tunnel ram vs aggressive intake w spacers? On paper (ie dyno simulations) the tunnel rams yield signifigant hp gains on these bigger motors when winding them up like yours with compression in the 10+range?
articfriends is offline
Old 09-26-2016 | 06:00 AM
whichever you try, really need to ck AFR with a 02 after, they change the signal to carb and therefore re-jetting may be needed
ezstriper is offline
