Prop help for an Adrenaline V24 >
Old 10-02-2016 | 11:13 PM
NWPC's Avatar
Default Prop help for an Adrenaline V24
Adrenaline V24 with 496HO. 26P Bravo at 4800 rpm hits 70mph.
Can I gain a few MPH by going to a 28P lapped
NWPC is offline
Old 10-10-2016 | 10:28 AM
Give it a try and find out.
AWOL is offline
Old 10-17-2016 | 07:36 PM
probably not, you should be spinning at 5200, try labbing it less pitch and a little more cup
class6 is offline
Old 10-27-2016 | 12:22 PM
bbladesprops's Avatar
Offshoreonly Advertiser
If the propeller is truly box stock, the correct lab process should get you to 5050 rpm and gain you about 2-3 mph.
Give us a call anytime and we can explain the process.
Brett
[email protected]
bbladesprops is offline
Old 10-27-2016 | 12:39 PM
GRH
Find yourself a 26 or 27 Mirage 3 blade.... not the plus ..... fastest prop for that boat
GRH is offline
Old 11-15-2016 | 06:42 PM
NWPC's Avatar
Will a Mirage Prop fit on a XR drive?
NWPC is offline
Old 11-15-2016 | 07:32 PM
as long as its not a solid hub prop
class6 is offline
Old 11-16-2016 | 10:02 AM
You will just need a HD FLO-TORQ Hub Kit
http://bblades.com/shop/hub-kits/mer...kit-840389k06/
Brett
[email protected]
Old 11-16-2016 | 04:57 PM
NWPC's Avatar
What prop will be the best overall for my set up?
NWPC is offline
Old 11-16-2016 | 05:52 PM
What area needs improvement , and what does not? I think you should try a stock 23P M+. don't think you have the HP to turn the 25 unless that bottom is on the flat side.
class6 is offline
