Speed gains from procharger on 22ft boat
Boat currently has 454 mpi mag with Stainless Marine Exhaust. Turns a 24p 5000rpms at 69mph. Procharger claims 620hp at 5psi of boost. What kind of speed gains should I expect? Before everyone starts in on me, I'm adding dual ram hydraulic steering before the procharger. Boat is a 1999 pq Raizor 22
Even if it makes 550, you are picking up 200 HP.
Couple things:
Take a hard look at the fuel system from the tank to the injectors
Consider head gaskets and ARP bolts
Crazy not to spend some time on the heads while apart
Odds are you'll want to get the prop shaft higher to get the speed gain you expect.
If 600 HP won't turn a 28-30 P prop on a 1.5:1 ratio in a 22ft boat, the hull isn't worth the work!
Couple things:
http://www.vortechsuperchargers.com/
The only one to go with.
It's going to make your nice dog into a mad dog.
Or like putting your foot in a Hornets nest.
Vortech does it right the first time to last a long time.
And you can clean the chiller on a Vortech.
Can not do that with the Procharger chiller.
Planned on doing some minor head work while replacing head gaskets and are bolts. I think the hull will be ok. It has a single step right on the keel 6ft from the transom. Also the strake on each side of the center stops at same spot. What does this small step actually do for it. If I sound ignorant about boat hulls....it's because i am, but I learn quickly
