bravo sea water pump with fuel pump opening >
Old 10-07-2016 | 10:05 AM
Default bravo sea water pump with fuel pump opening
looking for a good condition bravo sea water pump with fuel pump opening mine is leaking oil behind the pulley my fuel pump is good so i don't need one complete i can reuse my parts
basically need one that the seals are good in gene 617 957 1832
genob is offline
Old 10-07-2016 | 10:35 AM
Not a bad job to rebuild. Bearings and seals are readily available at your local supply house. As long as the eccentric is oaky and shaft is not grooved, you can repair. If you choose not to rebuild, I will pay shipping for the unit to rebuild myself and keep on-hand for a spare. Let me know if you need the part numbers for bearings and seals.
Cory H is offline
Old 10-07-2016 | 11:30 AM
Agree, pretty easy to rebuild and the parts will run you about $60. Rebuilt 3 of them in a day couple years ago
Just need
2 each item 14
1 each item 17
2 each item 19
http://www.mercruiserparts.com/bam/s...31804/2044/230
Pulley puller and a method to press in and remove the bearins
AllDodge is offline
Old 10-07-2016 | 03:59 PM
Wally's Avatar
Were doomed!
here's a DIY thread if you are interested in doing it yourself...
http://www.offshoreonly.com/forums/d...fuel-pump.html
-Wally
Wally is offline
