Rear Anchor
Old 10-12-2016 | 09:21 PM
Default Rear Anchor
Looking for advise on what to use for a rear anchor at our local sandbar. With our old boat I always used another anchor but with the new boat I don't have the space for a second anchor. I thought about a sand spike but I am reluctant that it will hold the rear of a 42 foot boat. The bottom is all sand and I use a fortress anchor in the front an it holds great. Thanks for any suggestions.
Esal is offline
Old 10-13-2016 | 07:43 AM
I hold the back of my 380 Powerquest just fine at the sand bar with my Slide Anchor spike. I love that thing, easy to pound in, and built in slide hammer also pulls it out easily. Only time I ever had a problem was when I was at a raft up with 5 other boats tied on and I had only anchors out and the wind picked up, and I was on the end. Pound it in the sand up to the d-ring and it holds a lot, especially if you add some backwards angle to it. Holds the rear of my boat and a 38' steal chris craft roamer on a regular basis. I use my standard Danforth anchor on the front. I do however want to buy a box anchor. I have been impressed with those too. Same company makes them.
Gimme Fuel is offline
Old 10-13-2016 | 10:31 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Sand Spikes are awesome. I bet you will be fine. The front anchor of the boat which is out in the deeper water is going to take a lot of "abuse" from the wave action, but all your rear anchor is there to do it keep it from going side to side. It's also a lot 'safer' from the aspect that it's much more visible on the beach or in shallow water than an anchor that is buried in. (It saves a lot of toes.)
Sydwayz is offline
Old 10-14-2016 | 10:30 AM
I made my own sand point / rear anchor. I have been using it the last 5 years and works great( Baja 265 and 33 OL). In big waves it will loosen up but I expect that.
I built a slide hammer on the top of it for hammering it down. Then to mark it, I have a shot 3 or 4 foot rope clamped to the top of it with a kids arm floatie on the other end of the rope. I get several "thank you's", "great idea" every year for the floatie to mark the anchor.
These are the only photos I have of it. Over all it is about 36" long with
92nsx is offline
