What are your thoughts? >
Old 10-14-2016 | 12:00 PM
Default What are your thoughts?
I have a NEW TO ME 2003 Nordic Rage with a 525ci 625hp mill. Bravo XR upper and imco lower currently spinning a bravo 24 p that looks thinned and worked. The boat will top out at 73-75 at 57-5800 rpm and gets there pretty quick. My friend has a bravo 28 p that I'm going to try out next season but I'm curious what you think. Is there a way for me to figure out the drive gear ratio without opening it up? Thanks
ELIMIN8OR is offline
Old 10-14-2016 | 02:20 PM
Figuring on 11%slip it's a 1.5
indysupra is offline
Old 10-14-2016 | 07:46 PM
How big of boat is that? Weight?
You can find the drive ratio by measuring how many degrees the input shaft turns before the prop shaft makes it 360.
I'd guess it at 1.5:1 and depending on how much work you have done to the 24 that you might like a 26 better.
TxHawk is offline
Old 10-17-2016 | 12:22 AM
It's a 25' And Nordic claims 3700 less power. So in the neighborhood of 5000 I would guess. My buddy has a stock 28 bravo I'm going to try next season
Old 10-27-2016 | 12:27 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Your slip is 12.5% because the Bravo 1 24 is only 23.3 inches of pitch with the stock cup.
I believe you will like a 26 better unless you decide to Lab the 28 B1.
It is dependent on the desired WOT of your engine.
Brett
[email protected]
bbladesprops is offline
