Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Gelcoat damage, how should I fix this? >
Old 10-17-2016 | 03:28 PM
Dave M's Avatar
Veteran: Navy
Default Gelcoat damage, how should I fix this?
What's the best way to fix this? It's about 3/4" long.
Dave M is offline
Old 10-17-2016 | 03:48 PM
Buy a gelcoat repair kit. A good one. And follow directions. Take your time and you'll never see it
class6 is offline
Old 10-17-2016 | 04:19 PM
glassdave's Avatar
Neno the mind boggler
looks like a small air void or bubble that finally let go. You'll have to open it up a bit to get to some good glass, because its on an edge maybe a piece of 80 grit wrapped around a half or three quarter inch dowel and just run it over the edge to leave a semi round transition. Traditionally 36 is best for a bond but because its on a sensitive edge you want to go a bit finer to keep it from fragmenting further. As said above the gel kits from West Marine work good for this kinda thing
08 OPA High Points Champion
glassdave is offline
Old 10-17-2016 | 04:34 PM
Dave M's Avatar
Veteran: Navy
Thanks Guys. I guess I should break off those fragmented pieces? What about putting some filler in the void?
Dave M is offline
Old 10-17-2016 | 05:42 PM
not needed. let dave answer that for sure
class6 is offline
Old 10-19-2016 | 02:25 PM
Knot 4 Me's Avatar
I had a couple of these right on the edge of the chine like yours on my boat. A gel paste kit from Spectrum worked perfectly. Been about 6 or more years now and repair is still invisible. Like Dave said, i took some 80 grit and knocked backed the edges a bit before filling.
Knot 4 Me is offline
