Screw in studs >
Screw in studs
Screw in studs
Old 10-03-2002 | 01:01 PM
BAD-HABIT's Avatar
Default Screw in studs
What is the best stuff to use as a sealer for screw in studs on cast iron heads??????
Bad-Habit
BAD-HABIT is offline
Old 10-03-2002 | 01:09 PM
kaama82's Avatar
I use teflon pipe dope...
kaama82 is offline
Old 10-03-2002 | 01:53 PM
ALFSTER's Avatar
Permatex aviation form-a-gasket part# 80019
ALFSTER is offline
Old 10-03-2002 | 03:26 PM
Head bolt studs=Permatex High temp thread sealant
Rocker Studs=Red locktite
Griff is offline
Old 10-03-2002 | 03:41 PM
razor1115's Avatar
I assume you mean small block engines with holes to the coolant passages??? - they need sealant. On BBC, the holes are blind and ARP makes a thread moly lube that works great - just run studs in finger tight, install heads, washers, nuts, then torque to spec
razor1115 is offline
Old 10-03-2002 | 04:10 PM
Panther's Avatar
Frank's Marine Service
Default BBC have water passages
Razor,
The Mark IV and earlier Chevy Big Blocks need to have the head bolts sealed. The Mark V and later blocks do not.
Bad-Habit,
Make sure you know what block you have before putting the sealant on. If you have the Mark V, or later block, use some heavy duty oil the lubricate the threads.
Panther is offline
Old 10-03-2002 | 05:24 PM
BAD-HABIT's Avatar
Thats where the problem lies.....ARP's instructions said to use their moly-lube or straight 30 wt oil.......STUPID ME just followed the directions....Im using the studs on a late-model sbc....
Bad-Habit
Old 10-03-2002 | 05:47 PM
Panther's Avatar
Default you gotta seal em up
yep,
You gotta seal them up. I use the Permatex Aviation sealant. You can also use Liquid Teflon sealant. GM makes this type of sealant, it works great. I got a couple of tubes from a crate motor a while back and have been using it ever since.
Panther is offline
Ken N
1
02-09-2008 09:46 AM
Ken N
12
02-08-2008 01:10 PM
220BR
2
11-24-2003 04:46 PM
BAD-HABIT
4
06-30-2002 05:56 PM
