How to remove injectors?
Either from the fuel rail, or the intake!
Simply pry them out from intake? Same for fuel rail? Or special way to do this?
Anyways, sent everything to engine builder and he took them out. Just forgot to ask him how he did...
the orings keeps them in the intake? or in the fuel rail? i already took the 4 bolts out of the fuel rail, everything moved but was stuck pretty tight in there... just did not feel like using more arm power! cause it can sometimes cost an arm!
There's o rings on both ends, do as wobble mentioned and they should come out
and do not pull or push on or from the connector portion of the injector itself. And when you reinstall injectors use new O rings and lube them with something like glycerin or waterbase KY.
Also there a few injector removal tools on the market.
And some people have made homemade versions as well
I have done this for eight years and here / there it has proven upon very sound advice to help track down any other internal problems within the cylinder(s), piston(s) and or ring(s) and or the ring seal.
Of course the other side is injector(s) that do not flow enough fuel as that can cause very lean conditions in that cylinder(s) (hole) so again inspection of that or those cylinder(s) would need further inspection.
The deal with fuel injectors is that you can have many flow great and produce great volumes but have one or more in the same group that is very poor at everything it needs to do. There is no rhyme or reason to how many are going to be good or how many are going to perform poorly or even completely bad.
I will say this, its very rare that I have tested used injectors and that set performs 100 % and 100 % exactly same when they are sent in. Even brand new injectors right out of the box sometimes do not even perform the exact same.
