598 Engine Advise >
598 Engine Advise
598 Engine Advise
Old 10-28-2016 | 08:39 PM
Default 598 Engine Advise
I pulled the engine out of my 27' V bottom due to high oil consumption and poor leakdown numbers. I knew it had a Merlin block and Brodix heads and not much else. It has a 1050 Dominator with a Dart intake. The Dart is a 4100 manifold with a 4500 adaptor.
The heads are BB2x with 345 intakes. Turns out it is a tall deck, 4.5 stroke with 4.6 bore. Full roller cam etc. A nice suprise to find out its a 598. Any good reccomendations as to cam, compression etc? I want a reliable pump gas, 91 octane engine. Thanks in advance.
Mach80 is offline
Old 10-28-2016 | 08:55 PM
Look into super victor 4500 or sv565 for starters. That intake is killing you.
getrdunn is offline
Old 10-28-2016 | 08:59 PM
14 apache's Avatar
What exhaust are you running on it?
14 apache is offline
Old 10-28-2016 | 09:02 PM
It has Imco Powerflows.
Mach80 is offline
Compression 10:1 conservative., cam I will be like a MT and lay low. You should spec out and see what's in it currently though. A particular grind I would hate to say without proven certainty. The heads ported? You wanting to go hyd or solid roller? What rpm you want to run at wfo? Another words what outdrive you have?
getrdunn is offline
Old 10-28-2016 | 09:15 PM
I would like to stay with a roller cam. Not sure what I want for a max Rpm. It was thinking 5400. I have the weak link here, its a Bravo One drive currently. I baby it.
Mach80 is offline
Old 10-28-2016 | 10:01 PM
I would like to stay with a roller cam. Not sure what I want for a max Rpm. It was thrning 5400. I have the weak link here, its a Bravo One drive currently. I baby it.
Baby it... Say whaaaat.
getrdunn is offline
Old 10-28-2016 | 10:22 PM
As best that I can!!
Mach80 is offline
Old 10-29-2016 | 05:35 AM
I have the perfect intake for that motor SV632 Edelbrock powder coated black nice no corrosion $350 pretty much half price. As far as a camshaft goes if you want the motor to be happy and 850hp right around 6,000 rpm at 10.0:1 compression you need a 273-275 intake high 280's exhaust @.050 113lsa works great the more lift the better. That cam with those heads and intake will pull like a freight train to almost 6,000 rpm and be all done by 6,200-6,300 rpm.
Black Baja is offline
Old 10-29-2016 | 11:22 AM
ROB FREEMAN's Avatar
my bob mandura cam he specked for my 598 was lot smaller than that , its for sale cheap brand new . in box id have to dig it out to give final specs .. 254 260 632 lift maybe not sure though
ROB FREEMAN is offline
