502 harmonic balancer >
Old 10-31-2016 | 07:09 AM
Default 502 harmonic balancer
Hi There,
i discovered an oil leak on my last run from the front left side of my engine, much more of a splash only whilst i was WOT.
since it was the other side of the oil cooler and seems to be splashing onto my fuel filter i figure it might have been from the crank oil seal.
after removing the damper to change the oil seal, i noticed that the part of the damper which fits into the oil seal seems a bit rough, so i guessed i should get a new one installed "since i believe was the reason of the oil seal to leak oil on high rpm"
now! my local dealer does not have a damper available, however i managed to get hold of a damper 3963532 number embossed on the back of it, seems to be the right one however has a different number to my previous one
# 10216339.
has anyone used same damper ( 3963532 ) on a 502 mercruiser before? should it be OK?
please help!
AlOstad_84 is offline
Old 10-31-2016 | 08:24 AM
3963532 is for a mark 4 454.10216339 is for a gen 5&gen6 454/502,they are different due to the difference in the back of the crankshaft.i would not interchange them.
mike tkach is offline
Old 10-31-2016 | 11:02 AM
They seem really the same, weight distribution and diameter.
Should I not fit it?
Old 10-31-2016 | 11:43 AM
If I remember correctly the gen 6 and mark 4 have a slightly different external balance to them. If your balancing your crank either will work, If your just bolting it on use the correct one.
kvogt is offline
Old 10-31-2016 | 12:25 PM
I purchased new aftermarket harmonic balancers, to replace my GM/Merc external balanced units. I brought them to a shop that specializes in balancing, and had them weight matched.
MILD THUNDER is offline
Old 10-31-2016 | 12:33 PM
The only available harmonic balancer I found is the 3963532.
Can I use it? What if I do? Any damage?
Old 10-31-2016 | 12:38 PM
http://www.gmpartsdirect.com/oe-gm/10216339
Old 10-31-2016 | 10:32 PM
Originally Posted by MILD THUNDER
i just ordered a gen6 block from them thursday.7 to 10 day delivery,no tax,free shipping.same price as summit but they wanted 111 bucks for shipping.
Old 10-31-2016 | 10:43 PM
My balancer balancing .
Attached Thumbnails 502 harmonic balancer-20161031_223913.jpg   502 harmonic balancer-20161031_223849.jpg
Old 10-31-2016 | 10:45 PM
I had a buddy order a pair of GM perf 502 partial engines from them. Fast shipping , and free shipping, and good price. Pretty sure it was from them. Ill have to double check to be sure
