2017 Ford Dually with 4:10 gear
Old 10-31-2016 | 06:32 PM
ROB FREEMAN's Avatar
Default 2017 Ford Dually with 4:10 gear
What a powerhouse. I can honestly say. This combo rock. My 16 Denali dually. No show compared to the new truck. All I can say is wow , can't believe the difference between the two trucks. [ATTACH=CONFIG]561065[/ATTACH]
Attached Thumbnails 2017 Ford Dually with 4:10 gear-img_0531.jpg
ROB FREEMAN is offline
Old 10-31-2016 | 06:35 PM
[ATTACH=CONFIG]561066[/ATTACH][ATTACH=CONFIG]561066[/ATTACH]
Attached Thumbnails 2017 Ford Dually with 4:10 gear-img_0527.jpg
Oops sorry don't know how I got two pics. My bad.
Old 10-31-2016 | 07:10 PM
Indy's Avatar
Member #154
Good grief...now that's a truck!
Indy is offline
Old 10-31-2016 | 07:17 PM
I'm very pleased 5 to ten inch kelderman air ride . its air down in the pics .. she can get huge ..or sit low . those are 37s , pretty kool lift .fly high or low tires tucked into the fenderwells ..
Old 10-31-2016 | 07:44 PM
I just got my 17 cc srw and it's so much better then my 15 ram 2500 same configuration. Really impressed right now with the quality and sheer power.
Schiada 30 is offline
Old 11-01-2016 | 11:21 AM
What gearing did your Denalli have in it? What are you seeing for RPM's now at highways speeds with the new Ford and 4.10's? Did you order it that way with the gearing or add it because of the tire size?
Sweet looking truck!!! Love the stance of it.
BIGSLOW is offline
Old 11-01-2016 | 12:13 PM
2017 Duramax has well over 900 ft-lbs of torque. I'm sure the 17s are pretty comparable with the same gearing.
MonkeySea2 is offline
Old 11-01-2016 | 12:22 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
1) What made you go with the Kelderman right off the bat? Any deficiency in towing with the stock setup?
2) What is the final drive ratio with the new bigger tire package? About 3.55?
3 ) Can you get some pics with it aired up?
Sydwayz is offline
Old 11-01-2016 | 06:52 PM
Thats thing is a beast! Nice truck man.
ICDEDPPL is offline
