Wanted Gaffrig Depth Sounder >
Old 11-08-2016 | 09:58 AM
Default Wanted Gaffrig Depth Sounder
Looking for a Gaffrig Depth Sounder that is in good condition. This would be early 2000 time frame, has digital readout, grey up and down arrow with the set button in the middle. There is cracking on the white face of mine and don't want to have to run a new transducer to install a new unit from Livorsi.
SC288 is offline
Old 11-08-2016 | 10:55 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Mike,
Humminbird actually made those and white labelled them for a few manufacturers back in the day.
http://www.sportsmansguide.com/produ...inder?a=458962
There are basically two kinds of depth finder gauges, and you can tell them apart by the connector.
When you pull the connector apart from the back of the gauge, one kind is rectangular shaped. And the other kind is barn shaped. IIRC, that one is a barn connector on the AT. (Looking at the end of the connector, the "barn shape" one is square on one end, and rounded on the other.)
If you can find a gauge with a barn shape to it, I think it will work, regardless of the label on the front. I don't know about the bezel though. When I bought the boat, the bezel on that was broken. I sent it back to Gaffrig (now Livorsi) to be replaced.
[ATTACH=CONFIG]561314[/ATTACH]
Sydwayz is offline
Old 11-08-2016 | 04:29 PM
I have a new old stock one in the box. I was going to use it before Smartcraft came along. I will dig it out if you want me to. Bob.
ren3 is offline
Old 11-08-2016 | 07:21 PM
Bob, I think I have a line on one. Can I let you know in a week or two if I need it? Thanks!
SC288 is offline
Old 11-08-2016 | 09:17 PM
I may have one of these packed away, let me know if all else fails
Brandon Anderson is offline
