will this combo cause reversion? >
Old 10-04-2002 | 12:46 AM
Default will this combo cause reversion?
I have a basically stock 454 magnum w/ an ultradyne 288/296 advertised, 231/239 @.050, .550/.575, 112 LSA cam. If I were to remove the low water Lightning headers and install the stock merc manifolds and elbows, would I be creating a reversion problem?
BGIII is offline
Old 10-04-2002 | 09:00 AM
It seems that most in previous posts said it (reversion) happens when you get at or around the 240* at .050 mark and your close, but let some of the experts come in to answer this one, why are you taking the good pipes off?.....Fred
fred is offline
Old 10-06-2002 | 04:02 PM
ttt
BGIII is offline
Old 04-03-2006 | 10:43 AM
Default Re: will this combo cause reversion?
bringing this back to the top since it I have the same question now.
delsol is offline
Old 04-03-2006 | 11:30 PM
I would say that that cam would most likely have reversion with stock merc exhaust.
Griff is offline
Old 04-04-2006 | 07:20 AM
Our guideline is 224 @ .050" for 'freeflowing' exhaust, and 235 for merc castiron.
BROWNIE is offline
Old 04-04-2006 | 01:30 PM
rmbuilder's Avatar
MarineKinetics
BGIII,
That cam is the second version Ultradyne that Harold did for Mercruiser in the mid 80's for the 440/460 cyclone engine package.
!st version:
288/296 at .0045"/.006"
231/239 at .050"
.550"/.558" valve lift, 1.7:1 rockers
110 LSA.
2nd
After several years, Harold changed the exhaust to the 296 at .0045, 239 at .050, .575" valve lift.
Mercury ran these cams successfully without reversion on a 110º LSA where yours are set on a 112º, giving you less overlap and a reduced likelihood of reverting. They are also soft lobes.
That being said, there are never guarantees when it comes to reversion due to multiple factors involved other than cam design. Intake/exhaust port velocities, combustion chamber design, and exhaust backpressure all play a part.
The history of this cam would indicate that set up correctly, you are good to go.
Bob
rmbuilder is offline
Old 04-04-2006 | 06:27 PM
Thanks for all the info Bob!
delsol is offline
Old 04-06-2006 | 09:46 PM
Crazyhorse's Avatar
Jesus, Bill,,,,,you get into some bad reefer or something? You sniffin' the RAID again?
Crazyhorse is offline
Old 04-07-2006 | 03:53 AM
cig1988's Avatar
What brand risers do you have? Had a problem with reversion & it was Sierra brand risers that cause the problem.
cig1988 is offline
Offshoreracr
Cigarette
9
03-29-2007 09:21 PM
Pat McPherson
29
12-08-2006 09:00 PM
BUIZILLA
Prop Talk
3
05-25-2005 10:49 AM
PatriYacht
12
08-08-2003 10:08 PM
speedmaster3
6
10-02-2002 12:42 PM
