Getting reversion and need some advise >
Old 11-11-2016 | 04:18 PM
TomZ's Avatar
Default Getting reversion and need some advice
Guys,
I'm running Stainless Marine exhaust with long risers on my set-up. The manifolds are the first generation style with short runners. The manifolds are definitely good. I'm getting reversion for sure. At first, I thought my misses at the ramp were being caused by high float levels and steep ramp angles which were causing a wet cylinder. I do not believe that to be the case now.
Running on the hose with the engine lightly surging at idle, I noticed that a cylinder dropped off. I revved it hard a couple of times, and she cleared up; just like at the ramp. Following a hunch, I shut the engine down and went to have a look at the exhaust. With a flashlight, I could see that the inner pipes were wet with water rolling down from the anti-reversion baffles. I removed a riser, and sure enough, I had some water in there; not much, but even a little is a lot in my book. This was evident on both sides of the engine so it's not a bad riser or manifold.
I'm going to replace the manifold gaskets just in case they're leaking and causing a vacuum (I've had the manifolds on a off a good amount this past season so maybe they're just toast), but I'm thinking that it may be caused by cam timing. I'm using a 525 EFI camshaft in my 454. I've gotten conflicting information on this: some say that this cam should not revert water with good risers and the supercharger, others have said that I should get it over with and convert to dry tails (I don't really want to make her any louder than she already is).
Pics of my set-up are attached. Any thoughts?
Thanks!
[ATTACH=CONFIG]561396[/ATTACH]
[ATTACH=CONFIG]561397[/ATTACH]
Attached Thumbnails Getting reversion and need some advise-242-engine-port.jpg   Getting reversion and need some advise-242-engine-starboard.jpg
TomZ is offline
Old 11-11-2016 | 05:08 PM
SB
A 454 will revert less than a 502 if they have all the same equipment.
What initial timing and idle speed are you using ?
SB is offline
Old 11-11-2016 | 06:35 PM
You sure the risers don't have pin holes at the bends?
indysupra is offline
Old 11-11-2016 | 06:43 PM
Dry Tails , Why waste your time any other way.
dunnitagain is offline
Old 11-11-2016 | 08:10 PM
TomZ's Avatar
Timing is locked at 32 degrees. I raised the idle to about 1K RPM. It has a little bit of surge at that RPM fluctuating as high as 1100 and as low 850. The cooler weather recently has changed this some. It was steadier in the summer.
TomZ is offline
Old 11-11-2016 | 08:12 PM
TomZ's Avatar
The risers have tested good.
I'll get pics of the risers after running. They are soaked just inside of the anti-reversion dams. It's sucking water.
TomZ is offline
Old 11-11-2016 | 08:13 PM
TomZ's Avatar
I'm close!
TomZ is offline
Old 11-11-2016 | 11:00 PM
The 525 cam has a lsa of 114*, right?
I have 110* lsa ZZ cam with CMI headers dry to their tip about 4" from the transom. When I pulled the heads the valves were fine and the ports a little sooty as they should be. Just doing the basic math I'm surprised that you'd have a problem. I did pull a plug out of the O2 bung hole and was shocked at how much water was shooting back out of it, but when it's left in place and removed it after shut down it was bone dry. It doesn't take much of a leak at all including the manifold/head gaskets.
I also had a Miss at idle but put a wideband on it and it was in the mid 10's, lol. A screwdriver cleaned that up.
Baja Rooster is offline
Old 11-12-2016 | 09:23 AM
TomZ's Avatar
I'm hoping the gaskets will help.
TomZ is offline
Old 11-12-2016 | 09:28 AM
A misfire, or plug not firing, can also cause water reversion. Same thing for a valve that is adjusted a bit too tight, or leaking exhaust valve. I have seen those stainless marine risers leak at the welds in the bend, like indysupra said.
MILD THUNDER is offline
