Dart block oil temp >
Dart block oil temp
Dart block oil temp
Old 11-16-2016 | 07:45 PM
Default Dart block oil temp
I recently had a new dart block built The oil temp seems to be running high it's running at 190 in the old one never used to get above 140-ish is there something I could check before pulling the motor
Jameslee540 is offline
Old 11-16-2016 | 07:52 PM
Yeah the whole water system. What is the water pressure?
Black Baja is offline
Old 11-16-2016 | 08:02 PM
Forgot to add the water temp is fine I have good sized oil cooler and the water pressure is around 15
Old 11-16-2016 | 08:17 PM
what is wrong with 190 oil temp?
mike tkach is offline
Old 11-16-2016 | 08:26 PM
Nothing a 218 oil thermostat wouldn't fix
BenPerfected is offline
Old 11-16-2016 | 08:29 PM
You running same sender and gauge? Same everything except for new build with dart block? You making more power = more heat. Personally I'd be stoked with 220 plus temps. 190 would be normal for many marine engines with coolers. In a nutshell id be more concerned about running 140 oil temps rather 190.
getrdunn is offline
Old 11-16-2016 | 08:33 PM
I run 140-150 oil temp. Makes the oil last longer. 170-180 block temp. Makes the parts last longer.
Old 11-16-2016 | 08:34 PM
Has the water pressure always been 15? Or did it drop?
Old 11-16-2016 | 09:14 PM
Same everything and it never used to get this high I did use a different builder this time I also have a bow tie block and it hardly gets above 140 that's why I'm worried
Old 11-16-2016 | 09:26 PM
the block itself should have nothing to do with the oil temp.can you give us more info on the new build.
