Shootout Organizers Decide to Shorten Course to 3/4-Mile Distance >
Old 11-17-2016 | 04:52 PM
Jason Johnson's Avatar
Correspondent
Correspondent
Default Shootout Organizers Decide to Shorten Course to 3/4-Mile Distance
Shootout organizers announce major decision to shorten courses to 3/4 of a mile in 2017.
https://speedonthewater.com/in-the-n...-mile-distance
Jason Johnson is offline
Old 11-17-2016 | 06:55 PM
Doesn't that change the whole character of the event? Now it's all about acceleration instead of top end.
thirdchildhood is offline
Old 11-17-2016 | 06:59 PM
Yep!
Stupid idea
TooLateVTEC is offline
Old 11-17-2016 | 07:26 PM
TENSION's Avatar
Enter the drag boats! "Wild Child" would re-write some records!
TENSION is offline
Old 11-17-2016 | 07:36 PM
Here come a new era of 30' pickle fork 10000+ HP SIngle engine boats
class6 is offline
Old 11-17-2016 | 07:44 PM
It already was a drag race. Just as an example, boats capable of 170 mph (with their highest pitch and lots of room) were lucky to hit 150 at LOTO and a prop change was required. The shorter course makes sense.
tomcat is offline
Old 11-17-2016 | 08:17 PM
SB
Shorter course makes sense at this point until something else come's about.
SB is offline
Old 11-17-2016 | 08:46 PM
top fuel dragsters were running too fast at 300 mph in the 1/4 mile so they went to 1000 foot, now they run 320 mph in less distance so not sure how the shorter distance helped. if you change the goal to reduce speed you have now created a incentive to achieve the previous speed with in the new parameter. racers, amateur or pro, rarely seek to slow down.
compedgemarine is offline
Old 11-17-2016 | 08:49 PM
SB
Shorter distance most definitely helped in your example. Think about it.
SB is offline
Old 11-18-2016 | 12:08 AM
they should have a good idea which class/classes of boats are going too fast. why couldn't they just have those classes on the shorter course same as they don't put pro stock on the short drag track? only top fuel. heck make it simple, all cats run the short course.
nocoolname37 is offline
