Locktight or not
Old 11-19-2016 | 08:19 AM
Default Locktight or not
What are the thoughts on locktight on engine assembly. Not dressing but assembly/rocker stud bolts/nuts?
BOATMAN302 is online now
Old 11-19-2016 | 08:31 AM
I use it every build arp fasteners too. Just uze red and blue where you should.
And ALWAYS balance your rotating assmbly.
I just balanced my evinrude 300 i took a kilo off each rod and piston pair.
iliveonanisland is offline
Old 11-19-2016 | 11:33 AM
I always do cam bolts and flywheel and coupler/damper bolts.
f_inscreenname is offline
Old 11-19-2016 | 12:00 PM
PL premium is another option Bruce
phil_p999 is offline
Old 11-19-2016 | 12:24 PM
14 apache's Avatar
Only spots I would even consider would be flywheel bolts to crank And camshaft bolts. And that would be about it.
14 apache is offline
Old 11-19-2016 | 06:25 PM
Tinkerer's Avatar
I used to use locktight on the rocker arm studs but never on the nuts. ( never had one come loose.) I used it on the flywheel to crank and the flywheel to the coupler bolts and also on the cam bolts. But that is about it. I have heard of people using it on just about every bolt. But keep in mind IF you use it on a bolt or nut that has to be torqued it has to be torqued right away and can not be re torqued later.
Tinkerer is offline
Old 11-19-2016 | 06:27 PM
Tinkerer's Avatar
I also used it on main studs but not on the head studs because You had to use thread sealant on the holes that went into the water jacket.
Tinkerer is offline
Old 11-19-2016 | 06:50 PM
Use it on Cam Bolts , Flywheel Bolts , Damper Bolt . The cam bolt is the only internal bolt that I would use it on. Thats why we have Torque Specs !
I use Blue on the bracketry for the accessories to prevent loosening from the vibration.
dunnitagain is offline
