37 Outerlimits "Diablo" Changing to SSM 6, Help please >
Old 11-23-2016 | 12:38 PM
Default 37 Outerlimits "Diablo" Changing to SSM 6, Help please
Looking for information for drive location to change the boat from #4 to #6 drives. Does anyone have a #6 boat with a side by side set up? Or can someone point me in a direction as to who to contact that would be knowledgeable and willing to help? Also will be selling #4 drives, gimbals, extension boxes and steering. Right hand drive needs lower gears and general go through. And looking for 6 drives and gimbals. Any help would be greatly appreciated. Thanks Madox
Madox is offline
Old 11-25-2016 | 08:05 PM
thunderusone's Avatar
You need to do a stagger on a #6 37. It will run horrible in a side by side application.
thunderusone is offline
Old 11-26-2016 | 08:39 PM
Bostonirish's Avatar
Probably not the answers your looking for but I agree. That would be a horrible move. Way to much weight in the ass end and those drives would be to far spread apart.
Bostonirish is offline
Old 11-28-2016 | 10:40 AM
What would be the optimum center to center and X dimensions? Anyone have pictures of a staggered set up in a 37? Particularly how close is the front engine is the back seat.
Madox is offline
Old 11-28-2016 | 11:53 AM
Unfortunately i believe the side by side 37's had a larger cockpit than the staggered set ups therefore your talking about cutting and moving the whole bulkhead forward to accommodate the forward motor.
Old 11-28-2016 | 09:25 PM
I would start at the same height as the #4s with 2" spacers in the #6s and then go up from there. Dont get discouraged you have to keep testing and trying different props and drive heights. Most single step boats will have more stern lift at high speeds, there are many good running side by side boats.
Equalizer is offline
Old 11-30-2016 | 01:07 PM
So your saying keep the drives at the same spacing (around 34") and put the x dimension at the same as the #4's. The consensus says side by side isn't the way to go. Trying not to get discouraged but haven't had any good options yet. Also had to put spacers in the #4's to make it drivable. Over 100 it would get scary. 1" spacers settled it down but runs slower. And with the 4's it sucks getting on plane, will not get up and go without taking it to 5200 rpm. I've been told that with 6's and a cavitation plate some of that issue will be solved.
Madox is offline
Old 11-30-2016 | 07:04 PM
TomFTM's Avatar
there is a 37 out there that was converted from a bravo boat to a #6 short stagger. If you look for edelecta in the activator area , he can fill you in. He had it done to his 37 that I just mentioned . He sold that boat years ago .but I'm sure he could give u some insite.
I have a 37 with number 5 's on boxes with the drives at 28 " and motors at 34". With 18" drive shafts .
TomFTM is offline
Old 11-30-2016 | 07:10 PM
plumbers crack's Avatar
You still got my trailer ??? Nice to see you in key west, I was trying to buy you a round and went inside to get some service and you were gone. It seems so easy to lose people in such a small town but its just insane !! Happy holiday's !!
Brian
plumbers crack is offline
Old 11-30-2016 | 07:41 PM
I would love to see pics of your setup if it's possible. I was thinking of doing something similar but a little afraid because I haven't seen one like that. How much HP do your engines make? And I'm assuming the u joints have held together.? And thanks for the info on edelecta, I'll see if I can look him up. Any info is greatly appreciated!
Madox is offline
