Anyone know these shifters? >
Old 11-25-2016 | 10:32 PM
Jim Diesel's Avatar
"Unregistered Gun"
Default Anyone know these shifters?
Recently purchased a 1996 Top Gun and trying to figure out the brand of shifter/throttles these are. I have a issue with the starboard throttle being hard to push the throttle from 1/2 position to wot, from idle to 1/2 throttle it slides fine. Still need to troubleshoot and see if it could be the cable or carb, but it feels more like the shifter needs adjusted so anyone have any experience with these?
Thanks!!
Jim Diesel is offline
Old 11-25-2016 | 10:36 PM
probably cable , disconnect cable from throttle and carb . Check the throttle first , if its good pull the cable buy hand , shouldnt be any tight spots or binding.
dunnitagain is offline
Old 11-25-2016 | 10:58 PM
Jim Diesel's Avatar
"Unregistered Gun"
I was going to check that first, then the carb. But really needing to know what brand these are?
Old 11-25-2016 | 11:47 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Hey Jimmy. You might get away with just lubing it. Here are a couple of methods. There are videos out there too.
http://www.boatus.com/magazine/trail...rol-cables.asp
http://goldwingdocs.com/forum/viewtopic.php?t=13272
http://www.triumphrat.net/air-cooled...tle-cable.html
Sydwayz is offline
Old 11-26-2016 | 12:00 AM
northernoffshore's Avatar
they look like older latham controls ..... you probably have a bad cable... i have these 4 sale if you have to replace 1. http://www.offshoreonly.com/forums/s...les-shift.html
northernoffshore is offline
Old 11-26-2016 | 12:31 AM
J-Bonz's Avatar
^^^^^ Thats what I was thinking, look to be like older Lathams^^^ BTW, Great looking Cig!!
J-Bonz is offline
Old 11-26-2016 | 06:46 PM
Marine Machine, have them in my boat
BenPerfected is offline
Old 11-26-2016 | 10:22 PM
Jim Diesel's Avatar
"Unregistered Gun"
Thanks guys, looks like it is the cable. Still trying to figure out exactly what brand of controls these are. I pulled the throttles today to check the cables and couldn't find any info stamped on them, they're pretty simple units and I didn't notice any adjustment for the resistance of the lever.
Old 11-27-2016 | 12:16 AM
Pretty sure they are older Marine Machine controls.
Lathams look similar but are designed differently.
Griff is offline
Old 11-28-2016 | 09:08 PM
Default Marine Machine controls
Picture posting challenged
