Thumping idle >
Thumping idle
Thumping idle
Old 11-29-2016 | 03:28 PM
Default Thumping idle
I have a pair of 496 mercruisers. One engine after warming up, especially on return in low power/idle in gear thumps or skips a beat. I suspect a bad IAC from rockauto. Performance seems fine. No issue when first started. Any thoughts??
38fountained is offline
Old 11-29-2016 | 04:03 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It could be. Do you have a access to a Rinda scanner? There is a full scope IAC test that you can run with a scanner.
Sydwayz is offline
Old 11-29-2016 | 05:21 PM
Originally Posted by Sydwayz
It could be. Do you have a access to a Rinda scanner? There is a full scope IAC test thatrun with a scanner.
. Yes, got one will run check next time out. Thanks....
