Thunder bolt V-6 34 module >
Old 12-01-2016 | 07:57 AM
F-2 Speedy's Avatar
Default Thunder bolt V-6 34 module
looking for a pair.............Lemme know
F-2 Speedy is offline
Old 12-02-2016 | 08:10 AM
MrCIG's Avatar
Charter Member#330
Are you looking for the V6-14 Modules? If so I believe I have 2. I need to check if they are here at the house or in storage.
Mark
MrCIG is offline
Old 12-02-2016 | 08:18 AM
F-2 Speedy's Avatar
Whats the total timing advance on those ??
Old 12-02-2016 | 08:29 AM
TomFTM's Avatar
v6-14 is 14 deg of advance.
TomFTM is offline
Old 12-02-2016 | 08:33 AM
F-2 Speedy's Avatar
that's what I thought, Mike T used some 6v 34's on a build, that's what Im looking for, or a 32* if they make one
Old 12-02-2016 | 09:16 AM
TomFTM's Avatar
Merc never made a 6v 34 to the best of my knowledge. 6v-14 . You set the base timing at 20 deg and your total will be 34 deg.
TomFTM is offline
Old 12-02-2016 | 09:27 AM
F-2 Speedy's Avatar
thanks Tom, I've not set one of these up, always done EFI............
Old 12-02-2016 | 01:32 PM
MrCIG's Avatar
Charter Member#330
Most guys with blowers or big cams used these instead of the standard V8 module. It gives you more initial advance to help the idle and shifting around the docks
The advance comes in earlier also
Let me know if you are interested and I'll look from them over the weekend. I have the distributors also
Mark
MrCIG is offline
Old 12-02-2016 | 01:45 PM
F-2 Speedy's Avatar
Im interested, I have one distributor but condition is unknown, send me a pm on what you have and a price, needing 1 engine harness also
thanks guys
Old 12-02-2016 | 06:19 PM
MrCIG's Avatar
Charter Member#330
I found everything I have ignition wise
I have 5 V6-14 modules
2 Distributors
1 V8-24 module
1 V8-20R module
3 extra harnesses for distributor to module
[ATTACH=CONFIG]562326[/ATTACH][ATTACH=CONFIG]562327[/ATTACH][ATTACH=CONFIG]562328[/ATTACH][ATTACH=CONFIG]562329[/ATTACH][ATTACH=CONFIG]562330[/ATTACH]
Attached Thumbnails Thunder bolt V-6 34 module-img_6443.jpg   Thunder bolt V-6 34 module-img_6440.jpg   Thunder bolt V-6 34 module-img_6439.jpg
Thunder bolt V-6 34 module-img_6437.jpg   Thunder bolt V-6 34 module-img_6436.jpg
MrCIG is offline
