502ci 525HP with Carb and Ign >
Old 12-02-2016 | 10:43 AM
Default 502ci 525HP with Carb and Ign
502ci 525HP
Started life as a 502/502 but has been run marine since new. I acquired and rebuilt early this year. Rebuilt by Keith Scroggins in OKC (known marine builder)
New bearings, rings, oil pump, timing set.
Heads were rebuilt with all new valves (stainless/inconel), valve springs and comp 1.7 RA's.
Cam is very close to a 525EFI cam in an Isky grind on 114lsa.
GM Perf Heads and Intake
I have a Victor Jr. Single plane I will include in sale
Carb is QF Marine 850
Ignition is Thunderbolt with HP module
I have run it for no more than 15 hours this season while I worked on the setup on my build. It pushed my 27 Excalibur to 80mph, so it is making some decent power. I can send a video of the last trip out in the boat.
I'd prefer to sell with Carb and Ignition as I plan to reuse everything else.
Stainless Marine Manifolds and Straight Dry Tails could be included for additional money.
$7,500
TxHawk is offline
Old 12-10-2016 | 08:20 AM
Last time this engine was run. If you're in need, I'll negotiate various options for the accessories.
http://www.youtube.com/watch?v=lFT-aZovsts
TxHawk is offline
Old 12-10-2016 | 09:08 AM
vintage chromoly's Avatar
That's a great deal!
vintage chromoly is offline
Old 01-11-2017 | 05:15 PM
Bump, spring is around the corner!
TxHawk is offline
Old 01-24-2017 | 04:40 PM
New motor is together, I am about to start robbing the accessories from this one.
I am offering it from the air cleaner to the pan to include Thunderbolt ignition. Ill throw in the crossover too!
TxHawk is offline
Old 01-30-2017 | 10:14 PM
What would be needed for complete swap?
AWOL is offline
Old 01-31-2017 | 12:35 PM
Sent PM with contact info.
TxHawk is offline
Old 02-08-2017 | 09:00 PM
Stripped and ready to go. Various accessories negotiable.
TxHawk is offline
Old 02-09-2017 | 08:24 AM
What is the new motor. Did you build one of the ones you got from me?
28cigarettess is offline
Old 02-09-2017 | 08:57 AM
I had another 502 block. Built a 540 with it.
TxHawk is offline
