Corsa Silent Choice Relay
Old 12-04-2016 | 11:55 AM
Default Corsa Silent Choice Relay
Looking for a replacement relay for my factory corsa set up on a 1997 Powerquest 380 Avenger. Part Number 962252b gets me nowhere.
Cory H is offline
Old 12-07-2016 | 12:17 PM
If your needing the 2 or 4 wire solenoid, they are no long made. The 3 wire is the only one which can be found unless someone is selling one on ebay. I gave my 4 wire stuff away when replaced all with 3 wire. Now it all sits on a shelf
If you need a relay (square 4 prong) which can be used between the switch to the solenoid harness, you can get one of those at auto parts stores or other places
AllDodge is offline
Old 12-08-2016 | 02:39 PM
Yeah, I figured out the relay. After I removed it and the wires, I found the required amperage. Went to 6 parts stores before I was able to find a person smart enough to cross reference the part numbers. These idiots have become too dependent on their computer and insist on a year, make and model of vehicle when I told them application will do them no good. You need to cross reference the part number.
Cory H is offline
Old 12-08-2016 | 03:23 PM
I hear ya, the brain in the head doesn't work to often with the young'ens. Good to hear you got it worked out
AllDodge is offline
Old 12-08-2016 | 04:06 PM
Kefurr's Avatar
where did you find it?
and if you don't mind what is the part number for future reference
Kefurr is offline
Old 12-12-2016 | 11:19 AM
I think, don't quote me on this, there's an EBay store selling replacement relays.
Jonesyfxr is offline
