Prop Size Trouble >
Prop Size Trouble
Prop Size Trouble
Old 12-06-2016 | 11:00 AM
Default Prop Size Trouble
Does anyone know who I need to talk to about the right size prop for my boat. The boat is approx. 12000 lbs. 40' Scarab twin 550hp, TRS drives.. I can not get over 42-4300 rpm. Top speed is low. and fuel economy is poor. (not really caring about that),
I was hoping someone can lead me in the right direction. I just don't want to start buying props.
chuckm is offline
Old 12-06-2016 | 11:24 AM
F-2 Speedy's Avatar
Currently running ?? prop
F-2 Speedy is offline
Old 12-14-2016 | 07:08 AM
I have 15.5 X 23 4 Blade
chuckm is offline
Old 12-14-2016 | 12:42 PM
Assuming the engines are running correctly, you're over propped. 550hp engines at what rpm??? At 4300 rpms, they are prob only making 400hp.
Every 1" drop in pitch equals about a 200 rpm gain at WOT.
Griff is offline
Old 12-14-2016 | 12:58 PM
I'd guess it came new with something like these.
https://austin.craigslist.org/boa/5872993139.html
GLENAMY 242SS is offline
Old 12-14-2016 | 03:32 PM
Team Archer's Avatar
Is that the 38 with a swimstep ? because that boat with TRS drives should run a 23 Bravo 1 3 blade. But if you have the generator and A/C it might drop down to a 21 3 blade
Team Archer is offline
Old 12-24-2016 | 09:03 AM
Default Scarab 400
It is the 400, Basically the 38' hull with the swim step as part of the hull , has the reverse arch. Does not have a generator. Motors run fine just trying to find out what size prop to go to since I feel what I have now is not correct.
chuckm is offline
Old 12-24-2016 | 04:40 PM
Default Prop
Call Dough at spinellie bros. He knows his stuff. I have a custom prop from him and it works great
Jj
conneroutlaw is offline
Old 02-17-2017 | 04:06 PM
Default Prop help
Give Doug at spinellie brothers a call he was very helpful when I bought a prop from him. He made the correct prop for my boat
Jj
Old 02-17-2017 | 04:42 PM
post #4, and the price is right. (thread is for 25's but post 4 has a pair of 23's)
http://www.offshoreonly.com/forums/w...5p-3blade.html
i might be wrong but, trs typical depth is like 7 1/4 inches and i think the bravo 1, 4 blade does not like to be that deep
outonsafari is offline
