Mannerfelt designs the HYPERCAT >
Old 12-16-2016 | 01:52 PM
Default Mannerfelt designs the HYPERCAT
SportBoatDesign by noli
Ocke & Ted Mannerfelt, a father & son duo, designs the HYPERCAT
noli is offline
Old 12-16-2016 | 01:53 PM
When you have a chance, please watch this video, very interesting father & son designers
http://youtu.be/Jj0kbGCGFV4 if you don't have the time to watch, here are my notes from the video
“form follows function”
“organic design”
“sleek in the back”
“rounded front”
“linkage to old race cars from the 40’s and 50’s”
“cockpit is interchangeable to pleasure cockpit by simply removing the hatch”
“the black area above the glass is an aftermarket piece to allow the removal of the hatch”
“the race boat is the same boat as the pleasure boat”
“Ocke’s son, Ted has a car design background and he used his car design background to design the HyperCat”
“the deck area around the front sponson has a ‘crease’ both for aerodynamic design and for walking safely on the bow and not slip”
“steps between the head rests aid the person when walking to the back of the cat… safely”
“the deck has winglets, like the tip of the airplane, built for speed and stability when cruising/racing at speed”
“beautiful shapes make for better performance boats”
“the engine shield also acts as a splash guard against rushing water so as not to destroy the engines when big water hits the motors”
“the hull is very efficient, at 75MPH she’ll burn 3MPG with Verado motors"
“the challenge to us when designing the boat is that we have to ‘fit’ the boat to an existing tall power plant”
“the motors are tall so we have to design to reduce that drag…the engine shield reduces the aerodynamic drag by 25%"
“with this deign, we can recycle old race boats to pleasure boats by simply removing the top hatch”
“the first pleasure boat will be built in the first quarter of 2017"
https://youtu.be/Jj0kbGCGFV4
noli is offline
noli is offline
Old 12-16-2016 | 01:54 PM
noli is offline
noli is offline
Old 04-21-2017 | 04:40 PM
Updates on the HyperCat. Designed by Mannerfelt & Swecat Racing
Deck Mold, nice and shiny
Hull & Deck for Delivery to builder
Nice Things on the tooling
noli is offline
Old 06-16-2017 | 01:56 PM
Swecat Racing builds first HYPERCAT hull
white gelcoat or epoxy primer being applied
noli is offline
Old 11-07-2017 | 12:36 PM
hull #1 is complete
The hull and deck are built all at once without manually glassing the deck and hull the traditional way
because the resin is infused, and the hull and deck molds marry together with bolts, the final laminate curing is done with both of the hull and deck together, in closed form
noli is offline
Old 09-26-2018 | 09:59 PM
well here it is
what we've been waiting for
Hypercat is launched!
Please read up on Swecat Racing in FaceBok.
noli is offline
Old 09-26-2018 | 10:10 PM
XCat will never be the same
XCAT Racing
noli is offline
