Vortec stroker quench build
Greetings all--first time poster but I've been searching, reading and learning a lot here while planning a re-power of my boat this winter. She's a 31' Marinette express cruiser--all aluminum with a loaded weight in the neighborhood of 7500 lbs. Single sbc. Obviously--I need a lot of torque--so I'm looking to build a stroker. This boat will rarely see WOT--in fact, I'd like to have the engine all-in well before 4500 rpm. And...it needs to run well on the crappy gas we often see at marinas around here, plus pretty restrictive exhaust manifolds--so I'm shooting for static cr in the low 9's. I'm hoping y'all will weigh in with your thoughts/suggestions/criticisms of the choices I've made so far:
Heads: Enginequest hybrid Vortecs, stainless valves-1.94 intake/1.50 exhaust- set up for max lift .520 cam, 64cc chambers Since they're hybrids, I can use my existing intake(Performer), carb(Holley 600) and valve covers
Crank: Scat 9000 cast steel 3.750
Rods: Scat 4340 forged, 5.700
Pistons: Speed Pro Hyper, D-dish to mirror head, +23cc's 1.425 compression height
Head gasket: Felpro stainless, .039 compressed thickness
Cam: Comp XM262 flat tappet 218/224 duration 112 lsa
Exhaust: standard cast iron marine logs, through hull
Assuming zero deck, I get a static cr of 9.23 and a dynamic cr of 7.58 with quench at .039. I understand vortecs will be more forgiving of lower octane if the quench is right--and .039 seems to be about spot-on. I thought I might be leaving something on the table with the 262--but when I plugged in the 270 specs, dynamic cr actually dropped a lot. This seems(to me) to be a pretty detonation proof set up--especially if I keep total timing to 32 degrees or less. Am I on the right track here? Am I being too conservative? Any and all thoughts gratefully accepted!
Comp cams specs the intake closing at .006 not .05 so I think your dynamic compression is quite a bit higher, probably 8.3 or so.
Are you zero decking it? They are usually .02 or so in the hole so you should account for that.
Seems like a good combo, but I would go with a roller cam especially if the block is a roller block. I have used the lt4 hot cam as have many others.
Thanks Mr Maine and CIG3. Just did more reading on rollers vs flat tappets--really does seem the way to go for good smooth power delivery. Plus no worries about zinc. I'm sold!
Any point in going with 1.6:1 rockers with the LT4 Hot cam given the low rpm nature of my cruising or would 1.5:1 be sufficient? And yes, I was planning to have the block zero decked
I don't think going with less lift will improve your low end, I would go with the 1.6s but only with full roller rockers. A 383 will take more cam than a 350 and will probably top out around 5k with that cam. Remember, a smaller cam will increase your dynamic compression and be more prone to detonation and spark knock at high load lower rpms.
Yeah, although maybe a bit less with stock exhaust and the performer. Should try to step up to the rpm performer for that many cubes.
To have it all in before 4500 would require a much smaller cam and you would lose horsepower and torque everywhere. Except maybe below a 1000rpms where a camper or tow truck might need it right off idle.
Looks to be a good combo. Quench is right on and that cam will build plenty of low end with the longer stroke crank. I have run that cam in a 355 and will say that it is plenty tame, which is a good thing. It wont revert with stock exhaust and will build peak torque nice and low. 4100-4300 if had to guess. Should make 370hp/400tq on 87octane easily.
For your Application I would drop the CR to 8.5 static, get a performer RPM intake and a 750 carb. and not worry about a roller cam. There are benfits to a roller, but to me on a mild 383 its money that could be better spent elsewere.
I've used it with glm aluminums which I believe are the same as stock regarding reversion and later stainless marines. Motor has ran 8 years without issue.
I agree about the cam, but if it's a roller block why put a flat tapped in it?
