distributor gears.
had a guy ask me what dist gear to use on his 8620 steel roller cam.he read that a steel gear must be used with a steel core .their is a lot of confusion on the subject so i will try to shed some lite on it.if the steel cam has a steel gear a bronze/mag gear is used.most 8620 core cams of today have a iron dist gear pressed on to the steel core [crane for sure does this].if your cam has the pressed on iron gear you have two choices on dist gear,melonized at around 75 bucks or composit at a little over 100 bucks.i have been using the melonized with excellent results.i think some more confusion comes from someone saying steel gear for steel core,their is some truth to that,the steel gear must be melonized .i am not going to discuss cast iron camshaft,s because flat tappet cast cams are a thing of the past and a cast iron roller cam does not belong in a performance boat engine imo.i hope this helps guys changing cam,s .
The more I think about this, we are using a external wet sump oil pump. So we really don't have experience with a composite distributor gear that is driving a standard wet sump oil pump.
coils on and efi baby.....
