Professional Motor rebuild question... >
Old 12-26-2016 | 06:09 PM
Default Professional Motor rebuild question...
So if you have a reputable engine builder who has been in business 30 years do a 6K engine rebuild but from the day you get the motor in it leaks oil and needs more repairs for oil leak whose responsible for second repair? Do you as the consumer have to rip cash all over again even though the motor was never working like it should or do they generally repair out of good faith? They always told me they had ideas on why it was leaking but could never get fixed where it didn't leak. I'm just curious what everyones opinions are here.
SunsationLarry is offline
Old 12-26-2016 | 06:42 PM
I can't imagine getting back a rebuild that leaked oil and considering that fine..
Pismo10 is offline
Old 12-26-2016 | 06:48 PM
Maybe suggest to the builder you'll mention his name as thinking its ok to have a newly rebuilt engine that pukes out oil.
buck35 is offline
Old 12-26-2016 | 06:49 PM
NO REPUTABLE Engine Builder would send you a leaking engine period . Now if you have accessories leaking , like oil coolers , power steering , sterndrive reservoirs. Thats on the customer OR the Mechanic to deal with.
dunnitagain is offline
Old 12-26-2016 | 06:58 PM
Well son, would you be having words with her pimp if your ho had anal leakage???
phragle is offline
Old 12-26-2016 | 07:07 PM
you want to go into a little more detail on this?sounds like this engine had this problem before.
sutphen 30 is offline
Old 12-26-2016 | 07:38 PM
They did rebuild last year and we put engine back in and would bleed out all oil by time I crossed the lake. My old mechanic couldnt find the leak so took it out and sent back to them and they said was fine not leaking. Got it back and took to my new guy who put in and still spewed oil from everywhere but they couldn't figure out where leak was from. Engine builder looked and thought was making to much crankcase pressure so leaking out valve covers and said I needed some valve covers with breathers. I barely used boat because of this and now the engine is out again and back there for a third time. Ive spent 13k on this one rebuild and pulling in and out few times plus little other work and didnt enjoy more than 3 days this season. They have that motor back and I'm probably taking other to them after his one is fixed right so they will be perfectly mated motors. How much do dyno test usually cost? They put on a stand with all the computers hooked up to it and I was thinking about having this done but its an additional 800 minimum they are saying.
Old 12-26-2016 | 07:47 PM
vintage chromoly's Avatar
You need a new machine shop.
vintage chromoly is offline
Old 12-26-2016 | 07:56 PM
Know of any in the Houston/Lake Conroe area?
Old 12-26-2016 | 08:09 PM
Who did the work?
GLENAMY 242SS is offline
