Donzi 28zx
Old 12-27-2016 | 08:02 AM
Default Donzi 28zx
Hello, just curious if anyone on the forum is running a 28' non step hull with single 502 and what top mph you are getting. I have a 98 donzi zx 28 with 502, I just bought the boat and the owner told me gps was about 65 with 4 people. I took it out this weekend and I'm only getting 55 on gps. Boat has k planes im not sure if these have a factor on this style boat I had the drive trimmed up and the tabs all the way up at wot. Any advice would be great! Thanks
Boosted502 is offline
Old 12-27-2016 | 08:16 AM
SB
The 28ZX should have a step.
Not the fastest of boats with a single 502MPI. Pretty heavy, crushes waves well. Fantastic engine compartment to work on things. I believe a 23"MiragePlus was standard prop ? Rode in one a million times but never with a GPS. Probably not much faster than low 60's...if that.
SB is offline
Old 12-27-2016 | 08:57 AM
scarabman's Avatar
At your 55 top speed, what RPM were turning? What prop is on the boat?
scarabman is offline
Old 12-27-2016 | 09:05 AM
Sorry the boat is the 27zx not 28, it has a bravo one prop 22p 4 blade and was running about 5,000 rpms
Old 12-27-2016 | 09:36 AM
You were lied to.
thirdchildhood is offline
Old 12-27-2016 | 09:53 AM
SB
Originally Posted by thirdchildhood
You were lied to.
Yeh, with a shoulder roll to boot.
SB is offline
Old 12-27-2016 | 10:27 AM
Boating Magazine tested speed was 63.7 with a 502 and Mirage 23. They, too, were disappointed (seriously, they said so in the article).
I say tested because I'm guessing they weren't full of fuel with 4 bodies when they ran that number.
https://books.google.com/books?id=F3...eed&f=falseThe
P.S., I just realized the test is a stepped 27zx. Cue a more disappointing number for a straight bottom.
Speedracer29 is offline
Old 12-27-2016 | 01:50 PM
A couple of other problems with that boat test. Article says it has a 502 but the picture shows a 454. Article also states that the 525 EFI is rated at 500 hp. Maybe Boating magazine should stick with Chaparrals and Four Winns'.
Old 12-27-2016 | 02:20 PM
scarabman's Avatar
Swap Bravo prop for Mirage, as already touched upon. 23 or you might be able to swing a 25 to an acceptable RPM and pick up a couple mile an hr. 65 is not going to happen, and never did for that matter, as already alluded to.
Old 12-27-2016 | 04:17 PM
Too late now, but sea trail before you buy again, sadly...you can't trust some of these guys. And like the others said, try to get your hands on a Mirage 23, see how that works for you. Good luck!
MullenTJ86 is offline
