poor oil pressure being found on new superduty diesl
well bummed out . ford starting to reviel engine oil issues , cause premature engine failure . , now saying only 1 percent . I call bullchit . frikken trannyies are also prone to leak also .. scurring to manufacture parts for that problem . many think deliveries are halted on the 17s ... yea ford . my 16 denali sure looked nice dammit ..
I read about that. Looks like its an oil pump issue on a certain production date range of trucks. Don't know anything about the trans. leak. First year of any make or model of virtually anything mass produced or machined, is always prone to a bit of consumer testing. Unfortunate but its always been that way.
[QUOTE=ROB FREEMAN;4517232]well bummed out . ford starting to reviel engine oil issues , cause premature engine failure . , now saying only 1 percent . I call bullchit . frikken trannyies are also prone to leak also .. scurring to manufacture parts for that problem . many think deliveries are halted on the 17s ... yea ford . my 16 denali sure looked nice dammit ..[/QUOTE
Rob,
That sucks, hopefully your AWESOME truck is not one of them. On a related note, we were thinking about selling the wife's 2009 Gen. 4 Viper, so I started researching the new Gen 5's, and found that FCA is having a engine block filings contamination problem, so we cooled our jets, and are just hanging on to her Gen 4 for the foreseeable future...
Rob,
Everything is for sale @ a certain $$
I can't believe that Ford is still in the light duty pickup business after the 6.0 and 6.4 fiasco and now all of the 6.7's sitting on the side of the road with exhaust sensor problems. It would in my opinion take a HUGE leap of faith to buy one of their diesels
I also know 3 people that own the 6.7 truck and haven't.
Maybe the are lucky.
That is the best report that I have heard about them. Seems like a lot of people are not having as good of luck as you. May I ask what brand of DEF you are using? I believe that a lot of the exhaust related problems from all of the mfg's may be related to that blue def that is being sold everywhere.
Same with me, no issue with 2012 6.7 F350. I use DEF out of the pump at Pilot truck stop by our house. What is the issue or post a link?
I am babysitting a buddy's 2013 F-350 for the winter; thanks to him letting me use it to tow my boat home this fall when my truck had an issue.
It's got 33K miles on it or so.
A couple months ago, I noticed it was leaking oil. I found the oil pan bolts loose & wet so I tightened them up myself. But I didn't take it out for a few weeks to heat/thin the oil and check the fix.
When I finally did, it still had a small oil puddle under it after parked overnight.
So I took it to Ford.
-No oil leak found, but it was leaking COOLANT. They replaced the water pump, and totally left the front end of the truck a greasy mess.
I drove it for a couple days, and then parked it.
Came back, and OIL under it, again.
I took it back in the shop, and they said it's leaking transmission fluid (which makes a bit of sense because I took pictures to show them it was wet with oil under the bell housing). However, what I was seeing on the floor of my shop was brown/clear; not like transmission fluid.
They replaced the torque converter claiming that was the leak. I haven't checked under it since I brought it home last week.
BUT, the last time they had it, they chipped the paint on the door. I swear, you just can't win.
I did have a leak like Sydwayz and I swore it was Oil from the lower seals or pan. Took it to dealer under warranty and it turned out it was the lines for the turbo. Was told they "All" will leak by the dealer and to expect every 100k to replace them. Nice stuff.
