Need some advice,procharger or 177blower >
Old 01-08-2017 | 05:30 PM
Default Need some advice,procharger or 177blower
I am looking to add some reliable power to my 500hp 502,.i am currently running.88 heads An a 525 cam hydrolic roller,.i have an opportunity to buy a procharger kit an a 177 blower,.i only am looking to add about 75-90hp around 4lb boost,.please help
Younggun253 is offline
Old 01-08-2017 | 05:55 PM
pass on both and get a 8.71,you and your engine will be happier!
mike tkach is offline
Old 01-08-2017 | 06:36 PM
I can't really afford that,..these are my options
Old 01-08-2017 | 06:47 PM
What procharger unit? The 177 is good to the upper 500's from what I recall off top of head. Above that she will make heat
Eliminated572 is offline
Old 01-08-2017 | 06:50 PM
There is zero comparison between the m1 procharger and a 177 or even a 250/256 for that matter. The m1 is much more efficient.
indysupra is offline
Old 01-08-2017 | 07:19 PM
502, with 250 blower, 525EFI cam, and Dart 310 Pro 1 heads. Non intercooled.
MILD THUNDER is offline
Old 01-08-2017 | 07:25 PM
I would not put a 177 blower on a 502.
Old 01-08-2017 | 07:44 PM
B38
I have 8 years with 177s on 454s reliable 100 hp addition. Sounds killer verses procharger. Both setups have 5 lbs of boost. Blower also less garbage to install. Fuel cool and water to air chiller makes for too much .
B38 is offline
Old 01-08-2017 | 07:51 PM
From: East Texas Waterfront- running errands if anyone asks
I'll just put this right here.
http://www.superchevy.com/how-to/eng...-on-built-454/
Flightplan is offline
Old 01-08-2017 | 08:55 PM
There`s another option: leave it alone till you can afford to do it right.
ICDEDPPL is offline
