Carb spacer or no ? >
Carb spacer or no ?
Carb spacer or no ?
Old 01-13-2017 | 07:43 AM
F-2 Speedy's Avatar
Default Carb spacer or no ?
Single plane application Vick Jr...930 cfm aerosol holley .what are you guys doing, YES or NO.any benefit
F-2 Speedy is online now
Old 01-13-2017 | 07:45 AM
8-10 hp every time so if it fits sure, if you have to do any mods to the hatch don't bother, might equal .5 mph
Unlimited jd is offline
Old 01-13-2017 | 07:50 AM
F-2 Speedy's Avatar
No issues with clearance, raised hatch...1 inch or more ?
Old 01-13-2017 | 08:10 AM
vintage chromoly's Avatar
4 hole 1/2" on top of an open 1/2"..
vintage chromoly is offline
Old 01-13-2017 | 08:17 AM
F-2 Speedy's Avatar
this looks good 4 hole and open
http://www.ebay.com/itm/2-silver-SUP...xYW0zz&vxp=mtr
Never mind its in China
Old 01-13-2017 | 08:21 AM
SB, are you still making spacers?
Old 01-13-2017 | 10:42 AM
bck's Avatar
bck
Charter Member#568
540 Vic Jr, 2in. vs none. I saw no difference with a 4 hole or combination. Regular 2 inch open.
Straight bottoms and flat decks
bck is offline
Old 01-13-2017 | 11:56 AM
Sonic30ss's Avatar
Identical engines one with 4 hole one with super sucker 4 hole.
SS made +6hp/+12tq, that engine consistently pulls 50 rpm more than other. Does it make a difference in speed, prob not, but mid range cruise (where I spend most time) is probably more efficient based on tq increase.
I'm going to replace standard spacer with SS in the spring to verify results.
Sonic30ss is offline
Old 01-13-2017 | 01:04 PM
Am I reading that right that the red line is with the spacer making less power?
Baja Rooster is offline
Old 01-13-2017 | 01:19 PM
bck's Avatar
bck
Charter Member#568
No, the better blue line is spacer and is making more power. The printer was running out of ink so the one line is traced over to darken it.
bck is offline
